Hi Charlie Weiler;
I have a feeling this is what you want this link I've provided below.
the orifices are usually not an issue -- 80 years of technological improvements re: shape, size, material used to create the channel the orifices are drilled in.... if its not lighting after 90 seconds and you pull the broiler drawer and see the igniter glowing red... it's weak - and not hot enough to trip the switch that allows the safety valve to open and allow the gas in. In the link is the replacement part and repair video. I have not checked the video for this particular model. but this company - sells the part and they are usually spot on with dyi help. (locally you should be able to buy an igniter .. $45.00+tax and replace in 3 hours - counting getting the part. Samsung Oven Broiler Problem
