Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
Stopped working today. will not come back on at all. lights come on like it is working, but drum doesnt roll
  • Maytag Master
  • 18,121 Answers
Check the belt, Remove the bottom kick panel and clean out the lint. turn the drum and see if it is broken or loose.
Posted on Jul 07, 2014
    New Friend:
Yea, I order a power board , should be here soon, dryer had no power, no lights. Your problem was a heat related sensor, heating element, is my opinion. Thanks,roy
Posted on Jul 09, 2014
6ya staff
SOURCE:
Dryer tries to turn but then shuts off
Hi espichfamily
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley this will cause the drum not to roll.
Check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Bud
Oct 11, 2012 | Amana NED7200TW Electric Dryer
Doesnt print black
There should be 4 individual drum units for each color feeding the transfer roll. No black means no black drum rotation or transfer.
Jul 27, 2010 | HP LaserJet 8500 Color Printer
Canon np6012f, all lights work, no trouble lights are on, yet copies come out blank, no image at all. Suggestions? Copies are coming out blank. Toner is not the problem, drum roll is not indicated.
How do you do. The Problem clear. This simply, back two questions. The First. The Scene is copied with transverse white band? Zdelayte check. She consists in following. You Do the copy and switch off the main by breaker just when sheet under drum. Afterwards remoove the drum. or see on it. If on drum scene by parts no, well test for newspaper, that question locked. Exactly, your бврабан came out of building, more exactly light on bright light, sun.Change the drum. Good luck you!
Sep 14, 2009 | Office Equipment & Supplies
Power window will not work
Test the window switch for proper operation at both switches, if neither works then you will have to replace the power window motor.
Oct 02, 2008 | 1999 Ford Taurus
Mr cars brake lights have stopped working
I take it the bulbs are good.
Look under the drivers side dash at the brake pedal. You will need a torch. There is a brake switch there and it may need readjusting or replacing.
Aug 04, 2008 | 2005 Peugeot 405
2005 Pontiac Aztek Parking Brake
The E-brake just needs adjusted up on the pads or rear shoes. If shoes on the rear instead of pads, it will hold from rolling back but not forward if not getting full pressure from the brake shoes needing adjusted up closer to the drum. It will hold from back roll because of shoe design. More shoe surface on the rear shoe than on the front shoe. That's the way they're built.
Nov 11, 2017 | 2002 Pontiac Aztek
Lam Error/Out
I contacted fargosupport.com and a technician walked through the solution, free of charge.
Jul 16, 2008 | Fargo Pro L ID Thermal Printer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
201 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
