Question about Sony KDL-32S3000 32 in. LCD Television
How to do a complete factory reset of a Sony Bravia KDL-32s5600 ?
My KDL-32S5600 showed a dark screen with the stand by light blinking 8 times. Uploading a newer firmware M5.167 did not solve the problem. How can I a complete factory reset of my Sony Bravia KDL-32s5600 ?
    New Friend:
    Problem Solver:
  • 7 Answers
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
Posted on Nov 18, 2015
6ya staff
SOURCE:
rustym62
Rusty Morales
  • 201 Answers
SOURCE: Sony Bravia KDL-40V3000 standby light blinking
I just worked on this last week 13 blinks means there is a problem with the backlights.So it can be 1 of 2 things bad inverter board( which costs less than $200) or the panel in which case you can thow the TV away as it will probably cost as much for a new TV.Unfortunately the set I worked on ended up being panel. If you try the inverter board just take your time removing it its plugged in rather tight I gently tapped it out with a screwdriver to get it started.
Rustym62
The TV Dude
Posted on Apr 27, 2009
Anonymous
SOURCE: How to do a complete factory reset of a Sony Bravia KDL-32P3000
Just talked with Sony Support today.
It seems that Sony in Denmark had sent out new software updates (over DVB-T) but also some wrong TV's got updated as well. This caused my DVB-T tuner to not function anymore so I wanted to try a factory reset and it fixed my problem.
So I was instructed on how to do this. I have a Sony Bravia KDL-32P3000 (which should be similar to the U3000 and S3000 as well).
This is how to do a factory reset of your Sony Bravia KDL-32 P/U/S-3000 TV.
PLEASE BE VERY CAREFUL WITH THE SERVICE MENU, YOU CAN EASILY CAUSE YOUR TV TO MAL-FUNCTION!!!! IF YOU FOLLOW THIS GUIDE IT IS AT YOUR OWN RISK!!!
Set your TV in standy (use the green power butten on your remote), RED standby LED is ON on your TV.
Now press these buttons in this order on your remote (pointing to the TV).
i+
5
VOL UP (+)
GREEN POWER button
NOW BE CAREFUL! Dont press any keys just for the fun of it!!! IT MAY DESTROY YOUR TV.
You should now be in the service menu. It will show up as some green letter/numbers spread over the screen (mine are a bit hard to see/a bit faded). In the upper right corner you should have 2 letters TT (two t's).
Now carefully press key 0 and then key 8 on your remote (they should be shown on the screen after the two TT).
Now wait a little while (more than 10 seconds) and your TV should reset with factory settings, just as if you had just brought it home from the TV store.
Best wishes,
Mads
Posted on May 15, 2009
Anonymous
  • 106 Answers
SOURCE: light flashing 13 times on sony bravia KDL-46x3100
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
Posted on Jun 16, 2009
Anonymous
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
tvtek
Duke
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
When I turn on my sony KDL-52W5100, its acting like its booting up (showing the sony and bravia)then the screen goes blank. Then the red light start blinking 6 time. what do I do/
Hi
there is a back light problem the connectors of back light are loosing so please go to your nearest Sony service center & solve the problem but if you know about led so remove the o cell & clean the connectors but if you are end user please don't open the led because the panel is thin
Dec 29, 2014 | Sony KDL-52W5100 TV
Sony KDL-52w5500 black screen 13 blink then 14 blink
You have a couple of problems if you are sure there are 2 different blink codes. 13 blinks indicates a backlight balancer error which would explain your no light condition. 14 blinks would be a TCON board error which is the driver board for the LCD screen. Either error would keep the screen black.
Mar 21, 2014 | Sony KDL-32M3000 32 in. LCD Television
My Sony BRAVIA KDL-40EX400 will not turn on.
IIC bus clock and/or data lines low at power on 06. This is the fault, according to the blinking codes given by Sony LCD TVs. That is, the fault lies within the main digital board. To locate the exact fault point to these type of fault, is actually a skilled one. If you wish to get more details to this fault, check the link sited here.http://electronicshelponline.blogspot.com/ It has details about these blinking codes. Before proceed, once again count and make confirm the number of blinks occur at one time switch ON. Pull up older posts by this link at its left side bar.
Jun 06, 2013 | Sony BRAVIA KDL-40EX400 40" LCD TV
KDL-40EX720, 4 blinks on a Sony Bravia
try making sure that the picture plug in the back of the television is completely plugged in.
Mar 10, 2013 | Televison & Video
Sony TV model KDL-46Z4100, standby light flashes 14 times, no picture, no sound
14 blinks to Sony Brand LCDs indicates a 'Backend error'. It means that, the main board to this TV should be checked for fault. In most cases the main board might need replacement, and a software update too. If you wish to know more details about this blinking code, check this link. It has details of blinking codes to several brands of TVs including Sony. Actually the work is a skilled one, need experience.
Jan 20, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Sony Bravia KDL-32S5600. Powers on for 35sec without sign of live
Switch off the TV, remove the plug and wait for at-least 48 hours before reconnecting. First try using a different power outlet. Also check for any jammed buttons on the remote. If the problem still persists, this might need attention by a qualified service technician.
Jul 15, 2012 | Televison & Video
KDL-40XBR4 bought 1/08. Turns on for 30 seconds with screen staying dark. Then it goes off automatically with the stand-by light blinking 5 times repeatedly. Took it to the shop and he said the LCD panel...
KDL- Bravia blink codes (Australian):
2 times-Main power supply voltage error (12V, etc)
3 times-Malfunction of 3.3V line
4 times-Malfunction of 5V line
(Voltage Supply to FE, etc)
5 times-Malfunction of power supply for screen
6 times-Malfunction of inverter or overcurrent, etc
7 times-Abnormal temperature inside unit
8 times-Audio circuit error (amplifier, etc.)
9 times-Fan malfunction
10 times- Digital FE circuit error
11 times-Malfunction of Trident IC or around IC
12 times-BH board error
13 times -Malfunction of balancer
If this is correct the 5 blinks is the power supply having problems, I would much rather change the PS than replace the screen. Also if screen is determine bad, look for class action lawsuit on Sony for defective screen, i am told they know all about this.
Mar 06, 2011 | Sony Televison & Video
Our Sony Bravia tv picture keeps going light dark light dark. What is causing this problem? It is very annoying when it goes dark because you can't see the picture. Please help.
I have Sony KDL-32XBR9 and I have noticed a similar problem. When the picture is showing mostly black, for example during the ending credits of a movie, the TV will further darken the display. Once the picture lightens back up, the TV will adjust the brightness of the display back to normal. I just called Sony customer support and they indicated it was a firmware problem and they will be sending a USB device in the mail to update the firmware. Hope this helps.
Oct 16, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony KDL-32S3000 32 in. LCD Television Logo
1,814 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
