I cut the cord
Remove the switch handle cover and you should be able to see all the connections and wires going to and from the switch. Undo the clamp at the cable entry area of the handle. Mark or note which way the live (brown/black) and neutral (blue) wire go into the switch. Wire in the new cable, refit the clamp and put the handle cover back on. Fit a plug on the other end of the cable and you should be good to go. Always carefully check the saw functions properly before using it again.
SOURCE: how do i replace the pull cord on my stihl cut off saw
it is gonna take some time,take all screws off housing,pull casing off,be careful with the rewind spring and be sure you have spring wound-up for re-install.
