Brother MFC 240C All-In-One InkJet Printer Logo
A
Anonymous Posted on Jul 07, 2014
How can i clear the memory on my printer? - Brother MFC 240C All-In-One InkJet Printer
maosee
Level 1:
  • Contributor 4 Answers
  • Posted on Aug 22, 2014
maosee
Contributor
Level 1:
Answers
Questions
0
Helped
6304
Points
10
Memory for the most part does not hold any information long term. It is used as a cache storage to hold a large amount of information for a short period of time. Memory was designed to take the load off of the CPU (central processing unit) and the hard drive(s). Once the unit has been powered off, within a minute or less, the memory has been cleared. The only thing that retains any information would be the hard drive. I hope this answers your question!
How do I clear the memory on a ECosys FS-C2126 Copy/printer
it is under mode 21, you need to login first to maintenance mode by punching the numbers 1087 1087. then select the number 21 then hit start. you will be able to clear the memory .
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
How do I clear the memory from my Brother HL-1440 printer?
Printer memory will clear if you simply unplug it from the wall. More likely, the old document was in your computer's disk, and you can control what prints from there.
I ned reset (lsu) for printer dell 1610n
[Clearing the Memory]
You can selectively clear information stored in your multi-function printer's memory.
Press <Menu> on the operator panel until "Maintenance" appears on the top line of the display. 1.
Press the scroll button ( or ) until you see "Clear Setting" on the bottom line and press <Select>. 2.
The first available menu item, "Paper Setting" displays on the bottom line.
Press the scroll button ( or ) until you see the item you want to clear.
Paper Setting: Restores all of the Paper Setting options to the factory default.
Copy Setup: Restores all of the Copy Setup options to the factory default.
Fax Setup: Restores all of the Fax Setup options to the factory default.
Fax Feature: Cancels all of the scheduled fax jobs in the printer's memory.
Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
All Settings: Clears all of the data stored in the memory and resets all of your settings to the
factory default.
Sent Report: Clears all records of your sent faxes.
RCV Report: Clears all records of your received faxes.
Phone Book: Clears the speed dial or group dial numbers stored in the memory.
3.
Press <Select>. The selected memory is cleared and the display asks you to continue clearing the next
item.
4.
Repeat steps 2 and 3 to clear another item. 5.
OR
To return to Standby mode, press <Return>.
[Page 130]
Dell Laser Multi-Function Printer 1600n User's Guide
ftp://ftp.dell.com/Manuals/all-products/esuprt_printers_main/esuprt_printers/dell-1600n_User's%20Guide_en-us.pdf
How to clear memory on hp 3020 all in one laser printer
Clear the memory on the product.
Press the ENTER/MENU button one time.
Press the < or > button until Fax Functions appears in the control panel of the printer.
Press the < or > button until Clear Memory appears in the control panel.
Press the ENTER/MENU button one time to clear the memory.
2helpful
The printer is in a free community center with 4 computers connected to the internet and to this printer. When trying to print a new page. The printer prints something that was in the memory from a...
There may be a function to clear the printer memory from the printer's control panel.
You can turn off the printer for a few seconds and then turn it back on. this will clear the printer memory.
I would like to clear all memory all memory from my hp psc950 before I throw it out. How can I do this?
The printer stores Fax logs and Speed dial/group dial no. Apart from this there is no other data stored in the printer.
Follow the steps below to clear the memory before you recycle it.
1. Disconnect the power cable from back of printer ( while printer is ON )
2. While holding the # and 6 key on printer front panel, connect the power cord. Release the button after 3 seconds
3. The printer will power off.
This will clear any memory stored in the printer.
Thank you for contacting Fixya.
* Please rate this solution with Thumbs up and comment to help us improve providing support
In use/memory light up and it won't let me fax.
To Clear the memory simply switch of the printer and power it on again. This will clear the data in the memory
3helpful
How do I clear the memory on a zebra gk420d?
Download the Seagull scientific GK420 ZPL driver. Version 7.16.
Open the driver file, (Double click on printer icon in printer & faxes folder)
Click Printer, properties, tools, action, reset printer.
Play around with the Seagull driver, it is very useful, you can format memory, read files stored in printer memory, see forms, fonts, images etc.
The forms stored in the G series printers are not cleared by the normal methods which one would use on it's predecessor the 2844 models. The G series will maintain the forms stored in its memory even if you download new firmware, or reset it. This is actually a good thing, as it prevents you from accidentally erasing forms stored in the printer.
Norman Weimar
Norman Weimar
k24674
