Its beeping every 30 seconds and the err is displayed on panel
Is it about 7 years old? The chemistry of the sensor is only good for 7 years, so by regulation they are required to have a timer that makes them die at 7 years, after which they are no longer accurate and could mislead you into a fatal CO poisoning. I presume you've already tried replacing the battery.
SOURCE: Nighthawk carbon monoxide alarm model kn-copp-b
Here is a link to the manual, or you can call the consumer hotline at 1-800-880-6788
1. Change batteries.
2. Clean it.
3. Swap it with another location if you can.
If it still does not work properly consult the local fire dept. for free.
You may have to take it in repairs if all fails.
SOURCE: our kidde battery operated Carbon Monoxide
Relocate it to an area of fresh air - outside will work.. Does it still beep?
If yes, recover the new battery and toss the unit.
Do you have it located in a steamy damp area? Laundry room, bath room etc.. That will cause it to malfunction too..
SOURCE: what do you do if your nighthawk carbon monoxide
If the display shows "Err", push and hold the Peak Level button. Does the display change to "E09"? If so, then you have just been "had" by the grossly under-documented "planned obsolescence feature" called, rather matter-of-factly, "End of Life". This means that ~7 years after first being powered up, the unit will, BY DESIGN, cease to function, forcing you to buy a replacement. Would have been nice of Kidde to include THAT warning on the OUTSIDE of the package. Call their "Hotline" at 1-800-880-6788 and tell them what you think of that policy. If it is still under warranty (5 or 7 years depending on date of manufacture) they should replace it. In any event, buy another one; if they replace your first one you will have twice the protection. Not a bad thing. *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera"The problem can always be solved with the materials in the room." -My college Physics Lab Instructor
SOURCE: My Kidde Nighthawk CO2 detector
"Err" displayed -battery icon may show any state of battery capacity. One quick beep every 30 seconds. Unit is Error condition
Replace batteries. If "Err" (or blank display) continues, unit has malfunctioned. Replace immediately.
Link to manual...
http://portalgb.knowledgebase.net/utility/downloadArticle.aspx?aid=294720
