SOURCE: My Frigidaire FRS6R35W0 refrigerator has ice in
Good day,
Keep pouring hot water into the drain hole. It can build up quite a way down. Be patient.
If no joy, service techs use a compressed air tank with a hose and adapter inserted into the hose where it terminates in the drain pan. If you have access to something similair then use it, but use very little pressure to prevent damage.
If not you will have to improvise. A tire pump with a short piece of 1/4" tubing inserted into the end of the hose will usually work.
Hello friend, that's a great question!
Typically the drain pan is located at the bottom of your Frigidaire refrigerator. You can look it by removing the toe grille. Hopefully this is helpful. -Matt
Good Afternoon Friend, I understand you want to know how to clean the drip pan on your Frigidaire refrigerator. The model number you have provided, JSI26, is actually the ice maker itself. I will be more than happy to assist you. So I am able to better assist, I kindly ask that you provide me with the model number of your dryer. Typically, this number is located inside on the left or right hand walls. Looking forward to hearing from you. -WP-
