SOURCE: Sennheiser PC 30 Headset not recognized on vista
My friend...
The sollution f this problem is to downliad this firware...install it and your headphones will be redy to play!!!
http://www.senncom.com/comm/icm_eng.nsf/root/support_faqs_pcusb_ms_vista
SOURCE: Sennheiser VMX100 not working with G1
make sure you oreder your bloothoth from htc and its for the g1 next time
SOURCE: My Sennheiser PC 166 gaming
Hi melamon,
Check the sound setting of windows, there is nothing wrong with your headset.
What windows do you have is i XP, Vista or Windows7?
anyways it is almost all the same just looks different on the windows version.
On the lower right side look for the speaker icon in the lower right side where the time is, then right click on it then select playback devices.
Once you have playback devices you should see a headset icon there if the headset is already connected.
right click on the icon then select properties or configure headset check the settings, also check the settings of the headset for the mic to see if there is an option to disable or set anything regarding echo or quality on the mic settings
Message me if you may need more info for further troubleshooting
