How to fix it
SOURCE: Norelco Electric Razor problem: Jet Clean System won't work
You need to fill the based to the max solution line. There is not enough solution in the container.
SOURCE: How much Jet clean solution do i use in the
The solution should not be deluted. You should fill the basin to the 'fill line' with the Jet Clean solution.
Jet Clean solution can be purchased at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-hq200-smart-touch-jet-clean-solution-p-258.html
If you do not know where th fill line is on your cleaning station, refer to your user manual. I would offer a link to the user manual but you did not state the specific model number of your shaver/
SOURCE: Norelco 8160xl jet cleaner. The top
Go to:
http://download.p4c.philips.com/files/8/8160xlcc_40/8160xlcc_40_dfu_aen.pdf
This is the only manual I have been able to find. Hope this helps.
