Question about Sansui DTV3200 32" TV
Hello! How I can remove parental control one the TV, diVISION DTV3200, without Remoute?
Have 2004 rca tv
Well, you've indicated that the issue is with a Nintendo DSi, so here's a solution for the parental controls on the DSi:
Wii Parental Control Password Resetter
May 01, 2014 | Nintendo DSi Black Console
Is there any way to get into menu to change from "ant" to "cable" without remote? TV does not have original remote and universal remotes will not access menu options.
Hold volume -/+ few seconds, menu will appear. Navigate up/down menu with channel buttons, page change with volume buttons.
Jan 21, 2014 | Sansui DTV3200 32" TV
How to unlock childs security?
RCA TVs come with a child lock capability called V-Chip. It's a parental control system which allows you to block programs and films by content, age-based ratings and the ratings which come with the movies. The parental control is a code, sent by the broadcaster to your television. The V-Chip will not work if the broadcaster doesn't send the control, or if the parental controls are switched off or unlocked. The controls are set up in the TV's main menu. The default is off.
Instructions
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu
Jun 28, 2012 | Sansui DTV3200 32" TV
Lost remote and tv is stuck on parental code screen mitsubishi cs 27205
Hello phillip and welcome to FixYa. A possible easy solution would be to power offf the television and unplug it. You should leave it unplugged for about 15 minutes. This Should remove the parental control screen and solve your problem. I hope this solution works out for you and good luck.
Apr 24, 2011 | Mitsubishi CS-27205 TV
How to program a universal remote for the Sansui
It may mean that the code you entered is incorrect. Try these: 0135, 0310 and 0394.
Jul 12, 2010 | Sansui DTV3200 32" TV
How do i change parental controls without a the
Press the number 9 and QV buttons on the TV remote control at the same time, when the passcode is requested.
Feb 11, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
How To Remove A Parental Lock Without The Remote Control?
That is called Hotel Mode. Look in your instructions for help.
Enter the service menu and select Hotel Mode to switch it on or off.
Apr 15, 2017 | Philips Magnavox MT2501C 25" TV
Remove Parental Control Password
I have forgotten the password for my parental control/content adviser window. Can you help me either remove it or change it without knowing the existing password. Thank you!!
Sep 05, 2008 | Curtis CM13102 13" TV
Sansui DTV3200 32" TV Logo
42 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
