both deal with the scanner located under the big glass. F-5 is bright light that comes on when you make a copy or the reader located under the glass that see the original, the E7 deals with shading of the original again under the glass get a tech to check out.
if its doing this with only certain senders it is possible the sender is scrambling their fax number. If so look in setup menu or tools and patiently study the settings.
Page 69 on operation manual suite
Source: http://files.sharpusa.com/Downloads/ForBusiness/DocumentSystems/FaxMachines/Manuals/fax_man_FO2080_suite.pdf
Error indicator is lit or blinking.
SYSTEM ERROR
[XX - XX] REFER
TO USER GUIDE
When [L1-00] appears, the scan head
locking switch is locked. Turn off the
power, release the scan head locking
switch, and turn the power back on
page 13 on the manual
The machine will not function. Turn the
power switch off, wait about 10 seconds,
and then turn on the switch again. If this
does not clear the error, remove the
power cord from the outlet, and contact
your SHARP service center.
I have never seen this error code on a sharp FO 5700 are you sure that is the right model # or error code. I even did a search in the FO5700 service manual(no luck). I believe I have seen this code before on a sharp copier.
