SOURCE: How to set numbers on speed dial
Main support number 1-800-338-9549, I'm sure they can help you
SOURCE: Programming speed dial numbers into NEC DTU-32D-1A phone
hit feature key,hit a line key,dial 9 plus the number,hit feature
SOURCE: I can't change the speed dial numbers on my phone
You should only have to hit Feature - Redial and then select the soft key that you wish to re-program. Typically you will then type 1 and then the extension you want to program.
SOURCE: trying to programme a speed dial key on a NEC DTP
Thanks for offer ....but as no answer on Friday I managed to email someone else at work who knew how to do it.
Cheers
SOURCE: I have a NEC Dterm Series II phone. I need to
This phone works on different NEC phone systems.Elite,IPK, 2000, 2400. Each speed dial code is different in each system. what system do you have
To set the system Time:
1. Press
Speaker.
2. Dial
728.
3. Dial two digits for the hour (24 hour clock, 13 = 1:00 PM).
4. Dial two digits for the minutes (00~59).
5. Press
Speaker to hang up.
