How do I oil my Brothers Runway CE5500PRW sewing machine
Place a couple of drops of sewing machine oil at every joint then let it run freely without the bobbin case, thread, and needle.
SOURCE: looking for a downloadable manual
you can download the manual for free from here
http://www.brother-usa.com/SiteSearch.aspx?sk=LS-1217
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
SOURCE: Oil Machine
http://gotoes.org/sales/BrotherSewingMachineManuals/ViewInfo.pl?Brother=1&Sewing_Machine_Model=LS_2125
Here is a link to where you can get a new manual.
SOURCE: brothers sewing machine ls 1520
I hope this is your machine, check it out
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1520_EN_270.PDF
ACCESSORIES
1 Buttonhole foot (1 pc.)
2 Zipper foot (1 pc.)
3 Button sewing Foot (1 pc.)
4 Needle set (regular single needle No. 14) (3 pcs.)
5 Twin needle (1 pc.)
6 Bobbins (3 pcs.)
7 Darning plate (1 pc.)
8 Screwdriver (1 pc.)
9 Extra spool pin (1 pc.)
Parts code for zigzag presser foot: 138135-051
Foot controller: X57319-051 (110/120V Area)
XA6422-021 (220/240V Area)
XA6412-021 (U.K.)
XA6414-021 (Australia, New Zealand)
The above accessories are stored in the accessory bag inside the
extension table. These accessories have been designed to help
complete most sewing tasks.
SOURCE: My needle broke on my Brothers LS-2125 sewing
You can use any brand of needle. The flat part of the needle faces back. Undo the little screw that holds the needle slightly until you can remove the old one. Put the new one in all the way up as far as it will go (flat to the back) and tighten the screw. I would recommend a size 14 ballpoint for regular sewing
