SOURCE: phone screen is black
With the phone off, hold * and # keys and then press power button:
- If your phone screen still dont show anything then the backlight or whole screen is broken and you would need to replace or make a technician to replace the screen.
- If your phone shows a boot screen with serial numbers on it, then you would need to re-flash or reload the phone firmware to recover your phone. For that you may need some special software, a PC and your phone's USB cable. You can find tutorials and guides over the web.
To get out the bootloader screen you need to take out the battery and the re-flash procedure delete all your data so I recomend you to download it with your phones PC software.
Good Luck...
SOURCE: Screen goes black. :(
My daughter is now going through two replacements for the screen going blank on this model. I'm still having to pay a deductible for a phone that was replaced the first time for the same problem this time. Evidently this is a common problem with this phone.
SOURCE: HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset
14 January 2008
You can also get tips & tricks from www.htcwiki.com
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
SOURCE: iphone black screen & buttons "pressed" while on call
I tried a solution to a similar problem and it worked for this problem, which I was having too. All I did was remove the leather case that I used to protect the iPhone. Calling and the screen worked like normal after I took the phone out of the leather case. Try that.
SOURCE: samsung impression cell phone touch screen goes
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is going black when you use the keyboard.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will not go black again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
