SOURCE: GE Refrigerator, Model TBX22ZA
One thing I might suggest is to check and see if the magnetic seal around the outside of the door is clean, tight, and fitted properly as this is one thing that can cause this condition.
the drain hole is blocked in the bottom of the fridge. if the water is not able to drain down the hole it will overflow into the fridge base. check any holes at the inside back of the fridge.
SOURCE: water/liquid collects at bottom of refrigerator
For water collecting inside of a refrigerator, there is usually something leaking inside, or perhaps the door seal is letting moist air into it.
SOURCE: My refrigerator is collecting water under the
The defrost water is supposed to go into a drain hole below the evaporation coils. The hole is clogged and the water goes down the back side of the refrigerator to the bottom. Seen it. You gotta clean out that drain hole. Shop vac works great.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: What would cause a refrigerator
hi there, refrigerators have condensation that forms and generally goes down a little hole that is usually under the fruit and vegetable drawers. This water should go down this whole into a condensation pan that is under the refrigerator and then evaporates. Sometimes food gets in the hole under the drawers and keeps the water from being able to travel where it needs to. Try to run a pipe cleaner of something through the hole to clean it out and maybe a very small amount of HOT water. If there is no hole there, it is unusual and it is possibly something else. This is usually the problem I have. Hope this helps!
