PANDIGITAL 7270FW Tablet Logo
A
Anonymous Posted on Jul 09, 2014
How do i reset my Apple iPad to factory settings iPad 3
Hampi Hemp
Level 3:
  • PANDIGITAL Master 706 Answers
  • Posted on Dec 06, 2014
Hampi Hemp
PANDIGITAL Master
Level 3:
Answers
706
Questions
0
Helped
238722
Points
6294
You need to connect your iPad to your computer and open iTunes software - there the iPad will show up and you can do a reset.
without a computer you cannot reset an ipad... Use iTunes to restore your iOS device to factory settings How do i reset my Apple iPad to factory settings i - reset-apple-ipad-factory-settings-ipad-3-m4xgx2guitusdoftp1eyswas-1-5.jpg
Reset Apple ID on ipad
Under "settings," go to "general" and look at the bottom where you'll find "Reset." This will reset your iPad to factory settings where you will be required to reset your Apple I.D. to your own personal settings.
To reset my ipad from apple
iTunes enables you to restore iPad to factory settings. Before restoring, please note that you need to install the latest version of iTunes on your PC or MAC. Then go to Settings > iCloud to turn off Find My iPhone. Now, you can factory reset your iPad with iTunes as follows.
1. Plug iPad into the computer with the USB cable. The iTunes on your computer will automatically launch. If not, double-click the icon to start it.
2. Click the name of your iPad at the upper right corner of iTunes, and then the information of your iPad will be shown. Click the "Restore iPhone" button in the window to start.
3. iTunes will ask whether you want to back up iPad before restoring. You'd better choose "Yes" for the reset will erase the contents in your iPad. Then iTunes will start restoring your tablet to factory settings.
4. Click Restore again to confirm. Then iTunes erases your iPad and installs the latest iOS software. After you restore your iPad to factory settings, it will restart. Now you can set it up as new.
http://www.leawo.org/tutorial/how-to-restore-iphone-6-plus-to-factory-settings.html
My iPad is disabled,how can I reset.
iTunes enables you to restore iPad to factory settings. Before you start restoring iPad to factory settings, please note that you need to install the latest version of iTunes on your PC or MAC. Then go to Settings > iCloud to turn off Find My iPhone. Now, you can factory reset your iPad with iTunes as follows.
3. iTunes will ask whether you want to back up iPad before restoring. You'd better choose "Yes" for the reset will erase the contents in your iPad. Then iTunes will start restoring your iPad to factory settings.
How to Restore iPhone 6 Plus to Factory Settings
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
How do I do a factory recovery on my mini ipad
iTunes enables you to restore iPad mini to factory settings. Before you start restoring iPad to factory settings, please note that you need to install the latest version of iTunes on your Windows computer or MAC. Then go to Settings > iCloud to turn off Find My iPhone. Now, you can factory reset your iPad with iTunes as follows.
4. Click Restore again to confirm. Then iTunes erases your iPad and installs the latest iOS software. After you restore your device to factory settings, it will restart. Now you can set it up as new.
How to factory rest ipad mini with out using the apple I'd or password
cant if icloud locked will need electronic tech assistance
1helpful
Setting up gave wrong email will not let me fix it
Barry, You may have to do a factory reset and start over, or contact manufacturer for suggestion.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apple iPad mini Retina How to master reset
Perform factory reset Apple iPad mini 2 128 GB
How to Easily Master Format APPLE IPAD MINI 2 RETINA DISPLAY with Safety...
Why won't it cut off?
iPad 2: How to Reset to Factory Settings - YouTube
? 3:30
www.youtube.com/watch?v=hf3E2X55tUw
Mar 6, 2012 - Uploaded by H2TechVideos This is a quick video tutorial on how to reset your iPad 2 (or 1) back to factory settings.
How to reset iPad
Reset iPad:
  1. Press and hold the Sleep/Wake button until the red slider appears.
  2. Drag the slider to turn your device completely off.
  3. After the device turns off, press and hold the Sleep/Wake button again until you see the Apple logo.
To Reset iPad to factory settings:
  1. Click on Settings > General > Reset
  2. Then if you want to completely remove everything from your iPad click on 'Erase All Content and Settings'
1helpful
I dot know how to reset my ipad
A factory Reset will wipe all the data stored on your iPad...everything will be restored to factory default, which basically means it will be just as you got it out of the box. It can be done by following these steps:
1.)Start by selecting 'settings'
2.)Than select 'general'
when in general scroll down to bottom of the page to 'Reset' and select it.
3.)Than you have the option to do a two things as far as Resetting your iPad.
a.) 'Reset All Settings' - This will preserve all your data but will restore all factory defaults..
b.) 'Erase All Content and Settings'. This will wipe all data and restore to factory defaults.
If you're giving the iPad to someone else or selling it...choose b.
Top PANDIGITAL Tablets & eReaders Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a PANDIGITAL Tablet and eReader Expert? Answer questions, earn points and help others
