Please try this procedure to reset the IP Phone Password and Connect it to some Other TFTP IP address(Another OXE) to register.
In industrial mode, the set will only work in a specific sub network, and
default IP address
- IpTouch IP address: 192.168.1.1
- tftp address: 192.168.1.6
You don't have to configure anything on the set, the address above are the
default "industrial" addresses
1)So, on your side you have at first to configure your PC with address "
192.168.1.6"
2)Then start your IpTouch in industrial mode:
- IP Touch starts in industrial mode thanks to key (i 1 2 3)
+ Disconnect power of the set
+ push key i
+ reconnect power (hold always key "i" pressed)
+ push at the same time "1" "2" "3" (and "i" of course)
+ when the leds go on, you can release the key
+ now, the set is in "industrial mode"
3)Use a crossed cable to connect your Set to the PC, or a HUB
4)Now you make a telnet on the set
5) Erase Thales Security
thalsec reset
6) Restart the set
The above procedure should work if it does not use following method.
First we need to telnet to ip touch phone. To do this use ippstat command and select option 15 and enter the directory number of ipphone and give timout time. Then you will see the following prompt.
NoePhone > config -h
config -h
ontinuation of previous activity.
config
set <ipaddr> <subnet> <router>
{tftp'tftp0'tftp1'tftp_backup} port <port>
{tftp'tftp0'tftp1'tftp_backup} addr <addr>
{tftp'tftp0'tftp1'tftp_backup} <addr> <port>
dhcp {s'd'a} static/dynamic/alcatel_only
boot {f's'n} full/standalone/no_binary
init_mode {c'd'0'1'n'a} code/data/custo/l10n/never/always
local_tftp_port {ls'<port>}
survi
mem
save <n> ' restore <n> ' r<n> (n in 1..4)
L10N'cust filename
For example:
config dhcp d to enable the DHCP mode or
config dhcp s and
config set 1.2.3.4 255.255.255.0 1.2.3.1 and
config tftp addr 1.2.3.2 to set static IP parameters
And then reboot the phone.
Now it should connect to the OXE and get the new password.
Check the link:
reset 4068 to factory default
Call your cell provider
