Since you can't restore to factory defaults by normal means, you should perform a Dead USB flash procedure (flashing phone without being on) You'll need the flash files for your mobile phone and Phoenix Service Software. Here is the tutorial:
Nokia dead phone USB flashing with Phoenix Service Software
SOURCE: Reset Nokia Mobile 1100 keyguard securtiy ccode
IMEI - 355398007170060
Security Master Code - 7027122524
SOURCE: Resetting Security Code
as of mine losing security code a big problem the only solution for this, reformat the mobile to clear the old file.
SOURCE: Forgot my security code
go to the following website, http://nfader.su/ and enter your imei no there. you will receive a master security code. you can use it to unlock your phone.
SOURCE: forgot my security code for
Use the default code which is 12345 or 00000, but if it does not work then you will need to send me the imei of the phone so i can help you out with a master code.
thanks.
