Question about Ricoh Aficio Office Equipment & Supplies
How to change pick up roller on Ricoh Aficio SP C231n
Anonymous
SOURCE:
Anonymous
  • 87 Answers
SOURCE: RICOH AFICIO SP C411 DN COLOUR LASER PRINTER
Open the side cover, and unlatch the plate. The PCUs are located in there. In the replacement PCU, there should be instructions.
Posted on Apr 01, 2008
Joseph Micallef
  • 86 Answers
SOURCE: driver for Ricoh Aficio SP-C210SF
Please browse the link below;
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11342&ricohmodelid=6317&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fspc210%2Fspc210en%2Ehtm
Good luck and please rate me, thanks.
Posted on Jan 29, 2009
Ickoajnc
OfficeServiceAjnc
  • 211 Answers
SOURCE: i have a ricoh aficio sp c420dn, when and turn on
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while
on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
Posted on Jan 13, 2010
dafonso
  • 24 Answers
SOURCE: I need to print the
From the manual:
"To Print configuration page, turn the printer off then while pressing and holding [the stop/start key] down, turn the printer back on, holding the key down until the READY indicator flashes once. The configuration page will then print out"
Posted on Feb 28, 2011
Testimonial: "Thank you. Could not find it on Ricoh's site."
bosegautam11
Gautam Bose
SOURCE: Ricoh Aficio SP C411dn error SC542
Ricoh Aficio error SC542
Posted on Sep 26, 2011
How to change feed roller on RICOH Aficio SP C242DN ?
1. remove all the cartridges.
2. remove the waste toner bottle.
3. rear cover
4. left cover
5. paper feed clutch
6. close the top cover and front door.
7. pull out the tray.
8. stand machine with the rear side facing the table.
9. slide the paper feed shaft to the left side.
10. remove the paper feed roller.
Jul 09, 2014 | Ricoh Corp Aficio SP C231N Laser Printer
How to change feed roller on RICOH Aficio SP C231N
You would need a technician to help out with the stuff.
Error sc540
Error code is related to the Heater section. You have to contact a technician
Apr 24, 2013 | Ricoh Corp Aficio SP C231N Laser Printer
Error sc540
fuser assy replace and reset code or have tech come out
I need part number of spc231n printer fusing unit
G166 4026 Fusing Unit - 120V
G166 4027 Fusing Unit - 220V
Mar 24, 2013 | Ricoh Corp Aficio SP C231N Laser Printer
Ricoh aficio SP c231n prints ghosts images
sounds like fuser is bad with wrinkling also or two different problems drum assy blade fail and fuser assy failed
Jan 02, 2013 | Ricoh Corp Aficio SP C231N Laser Printer
How to restart Ricoh SP C231n?
hi there, try to do the following:
- make a program mode (SP 107)
if you dont know SP mode, press clear/resume button then 1, 0, 7 then clear/stop button for atleast 5seconds.
*the monitor should appear 1.system 2.copy 3.
then press 1, then press 7,8,0,7 then #
*the monitor should appear COUNTER RESET then press 1 to start, let it finished then turn off and on your machine.,
*the SC-542 should disappear
note: if this will not fixed the problem, there maybe a problem with your FUSING UNIT, check it!
Nov 29, 2012 | Ricoh Aficio SP C232DN Laser Printer
22 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
