I have the transmission out ready to disassemble. I cannot find any info re: proper instructions of what I should look for or if internal parts for the transmission are available. I would appreciate your guidance.
SOURCE: will not agitate,spin or drain
There's a coupler that normaly goes.just tip the machine over and loosen the motor.the coupler will be 3 legged and plastic.just replace and it should be ok.
SOURCE: agitator will not work on wash cycle
Order the upper aggitator clutch/dog kit $15. Now top half of the aggitator is doing its thing just like the bottom half. Hope this helps someone else too.
SOURCE: Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
SOURCE: The washer has stopped spinning or agitating
it could be the brushes on the motor
does the motor turn
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
