SOURCE: canon pixma ip 1500
anon PIXMA iP1000
Waste Ink Counter Reset.
Step 1: Manual for Service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
Remark "After service mode Pls use software for permanent reset"
SOURCE: Canon PIXMA MP140 error code E 2
error E 2 =>
The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
SOURCE: canon pixma mp460 code error 6000
Solutions for error 6000
Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1.
Press ON/OFF switch to reset the multifunction device
2.
Removing paper jams MP450 / MP460
3.
The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
SOURCE: My Canon MP980 is showing Printer Error code 6000....
error [6000] or light blinking 3 times is mean there is an error occurred in the LF encoder signal.
