Question about Ricoh Aficio CL2000N Laser Printer
Video show of how to open the glass of my photocopier richo aficio 1018
6ya staff
SOURCE:
Anonymous
  • 78 Answers
SOURCE: Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Posted on Mar 19, 2008
Anonymous
MY PHOTOCOPIER IS ASKING FOR CODE SC194
Posted on Oct 11, 2008
Anonymous
  • 19 Answers
SOURCE: Richo Aficio 450e photocopy machine (Error Code SC360)
Replace HDD
Posted on Dec 24, 2008
SOURCE: RICHO AFICIO 650 SHOW ERROR 890
The code 890 do not exist like 880 but, if it is 980? the problem can be in the hard disc...
Incorrect parameter sent to the HDD controller.
First try reset the software… press the point and numeral key simultaneously until automatically it is off the copier, several seconds can pass, the copier back on automatically. The software will have been loaded again.
If the problem persists it proves with another hard disk,
since the other possible solutions already are more complicated; these are:
· Software defective
· SBICU defective
Another problem that sometimes cause erratic errors in these copiers is that it has fallen develop in some sensor having caused short circuits that annul to some times some voltage of the power supply interrupting processes indispensable for software. Example “by developer in the ID sensor” the copier scanned but nothing more. Developer in the sensors of the feeding units produced a code 322 can seem incredible but it is thus.
For it would recommend a deep cleaning of the sectors of the image unit and everything what is under the development unit.
Posted on Sep 02, 2009
boyrevel
jonathan white
  • 71 Answers
SOURCE: functional problem sc 541 for
SC541 = The melting temperature measured by thermistor is less than 71 C
The problem lies in the fuser:
- Thermistor fuser defective or incorrectly installed
- Fuser Lamp failure
Solution: Replace Fuser
Posted on Jan 05, 2011
I have richo aficio 2020 copier .toner motor is not rotating please help
Remove the toner botle clean the area and check the hole and the gear mechanism in developer station.
Feb 07, 2013 | Ricoh Aficio 1018 Printer
What cause faint copy on the photocopy machine?
SHORTAGE OF DEVELOPER, DIRTY LASER GLASS,WEAK DEVELOPER AND WEAK OPC, DRUM NIT NOT SET CORRECTLY IN POSITION.
Oct 31, 2012 | Ricoh Aficio 1018 Printer
What's the cause of faint print on a photocopying machine?
The toner could be low. That is the first thing I would check.
Sep 24, 2012 | Ricoh Aficio 1018 Printer
Functional problem sc 541 for richo aficio 1022 photocopier
Jan 05, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Large broad grey lines on all photocopies
Hello sir; The problem you have , you do need a drum cleaning blade to replace and also image transfer roller need to clean with alcohal.
May 26, 2009 | Ricoh Aficio 1013F Copier
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Hi it is the polygon motor failure error
2nd motor down on this link is what you need.
Nov 30, 2007 | Office Equipment & Supplies
Nov 30, 2007 | Ricoh Aficio 1018D All-In-One Laser...
Ricoh Aficio CL2000N Laser Printer Logo
20 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
