SOURCE: I need a user manual for Adler Royal Satellite 80
Go to www.nadist.com and download the manual for the NAKAJIMA AE-740...its the same machine and its FREE.
SOURCE: Royal Satellite II manual typewriter. I replaced
reinstall ribbon and make sure its not hitting on any thing,
SOURCE: TA Royal 503 typewriter with a print wheel that is not aligned
Hi - there a many reasons why this happens. Try these first. Replace the ribbon. This might have become tight (faulty) and make this happen. Next clean the main rod that the carriage goes back and forth on, it sometimes get very sticky. Then place a couple of drips of oil on. This should work wonders? Best John ex OEM trained mechanic
SOURCE: Adler Royal Typewriter Satellite 80
On the lhs of the keyboard check the Pitch Sel slide switch position;...it may be in the PS position...change it to 10,12 etc, to match your print wheel.
SOURCE: Where can I get instruction
I believe this is the same as a Nakajima AE710. Go to NADIST>COM, click on current models you will find a manual there.
DickyO
