Question about Pioneer DEH-P7800MP
I have a Pioneer DEH-P5900lB stereo, the CD player is working but I have no controls or LED display from the front panel.
Why is the LED display not working on the front panel of my DEH-5900lB pioneer stereo? The Cd player works but I have no controls.
    New Friend:
It might be the faceplate
Posted on Jul 11, 2014
Anonymous
SOURCE:
starlet4life
jesper johansen
  • 89 Answers
SOURCE: Pioneer automotive stereo cd player error 11
Error 11 is probably the laser...;)
Posted on Sep 26, 2008
mikehumble
  • 124 Answers
SOURCE: how do i turn aux on my pioneer deh-7600mp radio
Shut it off then hold the function button, cycle through till you find your option to turn it on, the turn the radio back on and use you source button to change to CD, TUNER, and AUX
Posted on Dec 27, 2008
Anonymous
  • 61 Answers
SOURCE: How do you get the Pioneer DEH-P670MP car stereo
hi there
to fix this press and hold the source button till unit turns off the source button switches from CD - radio...................once your unit powers off........press and hold the function button down till the clock appears in display you should also hear a beep when this happens.........press the function button repeatedly until the telephone feature appears now switch by pressing the skip button to ATT (Attention) once this is done press the source button to power on the pioneer unit simply turn up the volume and problem should be solved......
hope i was able to help
Posted on Mar 05, 2009
Anonymous
  • 61 Answers
SOURCE: Pioneer DEH-2150 : CD Ejection switches off the Stereo
hi rolls
when there is no CD in unit hold the source button to turn unit to actual on position (when you insert a CD is it self guided once you push it to a certain point or does it just self guide instantly) if you sort of push it in a bit and unit turns on its because the pioneer function says to itself i need to be on so it will play for you but once you eject the CD the unit says time to turn off the solution i recommended should solve this if not let me know and ill figure out another step
Davis M
  • 166 Answers
SOURCE: Need Wiring Diagram for a Pioneer MOSFET 50 Wx4
Found the manual on Crutchfield's site
The wiring diagram is on Page 25
Posted on Jan 23, 2010
I have a Pioneer DEH-P3600 detachable face car CD receiver. It has been working great until a week or so ago. After removing the front panel, turning the car off then reattaching it and starting the car...
did you clean the contacts on both the face and the subpanel? what did you use to clean it with. usually qtips and rubbing alcohol or a pencil eraser work best.
Feb 28, 2011 | Pioneer DEH-P3600 CD Player
Front display panel keeps coming off cd player
You can purchase a new back piece to it and that should fix it . They generally run $20.00 or less
Jun 19, 2009 | Pioneer DEH-1100 CD Player
THE SECOND DISPLAY SCREEN STOPPED WORKING
I have the same deck. replace the flex ribbon to sub panel. It's a problem with this deck. I've replaced the rear panel ribbon numerous times as well as the front panel ribbon.
Jun 18, 2009 | Pioneer DEH-P9600MP CD Player
DEH-960MP CAR CD PLAYER STEREO RECEIVER DISPLAY PROBLEM
its the ribbon wire inside i have the same deck with the same problem and it cost me 100$ to have it fixed since the warranty was no longer valid any pioneer repair place can do this for you. All you need to do is take them the head unit not the wiring harness so at least you dont have to unhook it all
Mar 14, 2009 | Audio Players & Recorders
How to make mp3 work on DEH P3500 ?
when it says mp3 it means you can hook an mp3 player to the stereo and play music that way. if you have an mp3 player you need a cable that will hook the mp3 player to the stereo and you can get that cable from pioneer.
Nov 16, 2008 | Pioneer DEH-P3500 CD Player
How do you eject the damn cd out of the pioneer DEH-P7900BT
Your Manual
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/429287552DEHP7900BTOperationManual0328.pdf
will go over all the functions in detail.
3 EJECT button
Press to eject a CD from your built-in CD
player.
Press and hold to open or close the front
panel.
Bottom rightmost button.
Nov 11, 2008 | Pioneer DEH-P7900BT CD Player
Having trouble settimg clock on cd car stereo
how to set clock for a pioneer deh-27mp
Mar 24, 2008 | Car Audio & Video
Pioneer deh-p750 locking
Try pressing the reset button. It is usually in a little recessed hole on the front panel.
Aug 28, 2007 | Pioneer DEH-P750MP CD Player
Pioneer DEH-P7800MP Logo
251 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Sumeet Sodhi
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
