Vivitar ViviCam 8025 Digital Camera Logo
A
Anonymous Posted on Jul 11, 2014
What does pc camera mean - Vivitar ViviCam 8025 Digital Camera
After removing windows xp for windows 7, camera stopped working
If by camera you mean webcam on laptop, then you may be missing driver, or certain piece of software to make it run. If you mean an external camera, and by stopped working you mean it will not import automatically then there may be a driver issue with camera. Installing any software that came with camera should help solve this. More specifics on what you mean by "camera" and "stopped working" would help
How to Transfer the internal photos taken to the card
what do you mean? transfer from internal camera memory? try to get the memory card out of the camera then connect it with usb cord to PC, copy it to PC then copy it to memory card.
Cannot load pictures from camera error 0000225
Do you mean upload them to your PC ? sounds like PC software error not the camera.
2helpful
My 24280 dig. Wont charge
the pc function means that it is connected to your computer this is good because now you should be able to upload pics and ect...the red light is simply to show its charge level and is always on when plugged in to computer also there should be a switch on the side to change from camera to charge if its on charge and the light is red then its carging and it will turn green when its done.
IBM Video Conferencing PC Camera Webcam ksx
IBM 33L4889 Digital Camera drivers for xp. contact me at [email protected] and will discuss means of file transfer
May 08, 2009 • IBM Webcam
Webcam breakdown
check in the device manager, if your camera is there.
it's supposed to be under imaging device.
if it isnot there, it's mean something wrong with your camera, it could be camera cable or camera itself.
if it is there, it's mean software problem, try to reinstall application software. if you don't have it you can download from www.acerpanam.com
The display says PC
No that means it's plugged into a PC and the light turns green when it's charged! =]
2answers
Charging battery
I have the same camera.
But when your camera is flashing the green light, that means it's transferring pics.
If the light is just green on the camera, that means that it's charging i think.
But i don't know how to tell when my camera is through charging is my problem.
Nov 23, 2007 • Cameras
Faulty memory card - card error.
hi, May be, it is possible, but take a chance, try with another memory card, i hope you will get it from your friends. check the camera with that, if camera works properly means problem in your memory card.If camera not works means,there is something wrong in card accessing circuit of camera. If so go to olympus shop. also try to format your memory card with pc and then check the camera with that. good luck
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
