It was complaining about the toner but after i have changed the toner with the new one it still gives toner error message and its not working
SOURCE: MFC 8460N giving Toner Life End message
I just solved my own problem. Try it for yours. I had been using several compatible toners for the MFC-8460N with no problems until today, as I posted earlier. On a hunch, I went to the local office supply store and purchased one original Brothers TN550 toner and put it into the printer and closed the cover. Everything clicked. Toner End Life message gone. I then took that Brother toner out and put the compatible one back in and still everything was fine. Am keeping the original Brother toner as a "kickstarter" if it happens again.
SOURCE: how to get ride of Toner life end message
You could try resetting the toner cartridge settings. OPen the machines front door where you would replace the cartridges. On the top panel you will see a "clear/back" button. Press it and on the display you will see a reset menu come up. Arrow to each one and hit the OK button. Press "1" to reset. Once you have gone through all close the front door of the machine and press stop to bring the display back to normal.
Hope this helps.
SOURCE: Brother MFC 7820N Toner life end with new toner
I found the following post on another site. It appears to work.
If you want to reset your Brother MFC 7820N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 7820N should be reset and the Toner End of Life message should disappear.
WARNING: This may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
SOURCE: Message on Brother MFC
Open door
press Clear/Back key
press *00
press OK
Do not
choose anything for drum replacement. when drum replacement menu comes
up, just press the * and then 00, then just press OK.
that should clear the error message, the printer has a toner life counter that needs to be reset.
