Ive tried everything
SOURCE: My phone says No service
THE EASIEST SOLUTION IS TO GET OUT YOUR MANUAL THAT CAME WITH YOUR TRAC-FONE, AND CALL THE NUMBER THAT REFERS TO SERVICE. THEY WILL HELP YOU DETERMINE WEATHER IT'S THE PHONE OR THE SERVICE THAT IS THE PROBLEM. ANOTHER ALTERNATIVE IS TO GO TO, "TRAC-FONE.COM", AND GO TO THE SERVICE/HELP AREA..................... GOOD LUCK, JLR4
SOURCE: Motorola VGA Zoom 4X can't transfer photos to computer
you need to check for a usb driver for your mobile phone
SOURCE: tracfone
Absolutely, what you need to do first though, is have your IMEI and SIM serial numbers handy from the first phone. Simply push the center, round button in the middle of the top array, and it should open to Prepaid, select that and go to the 2cd option which is IMEI and select that, and write down that number. Then do the same thing with the 3rd option, which is SIM. Once you have those 2 numbers in hand, do the same ith your new phone. Once done, call the 1 800 number for your area and speak with a represenative and they will walk you through the rest of the proscess and add your existing minutes to your new phone.
SOURCE: FREE SUBSIDY PASSWORD
you can't switch SIM cards from one tracfone to another. forget trying to find a subsidy password.
