1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor.
2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu.
3. Use the down arrow button on your monitor to select "Factory Reset."
4. Push the menu button.
5. Use the down arrow button to select "All Settings." Press the menu button to save changes.
6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
If you have a B. Crocker bcf1690 machine you need to just plug it in and it will always default to the regular bread program. To change it to whole wheat you need to press the Menu button until the whole wheat program shows on the display ( #3) according to my manual if you go past it just keep pushing the menu button until it comes back around again to #3. then just push the start button.
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time. 2. Menu window will show "OKI USER" 3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button. 4. "Diagnostic Mode xx.xx.xx S-Mode is indicated. 5. Scroll to "NV-Ram initial" is indicated. Push ENTER. 6. Window shows "NV-Ram- Initial Table 1". 7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window. 8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%. Hope this helps
Positive Feedback ALWAYS Appreciated :)
- pull out the AC plug - put back the AC plug while holding down the "menu" button and keep holding it (15 sec) - now you are entering the MAINTENANCE mode and "error 46" pops up in the display - select 8 by using the arrow buttons ,push OK and select 0 and push OK - 00:00 00:01 OK (the display is showing this message) - now push the MONO button 25 times until you see PURGE: xxxxx - Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok - the purge counter indicates now: purge: 00000 - switch off the printer ,switch it on - ready to print
hello try to do this
press menu#1934 and right arrow key
disply show ready tech
press menu button and press left arrow key
display show new cartridge.press enter button twice.
then restart your printer.error message didnt display
I had the same problem with my HK AVR 355 and The Bridge II. Yours has entered manual mode by itself?! You think the bridge it did by itself but You did it. I tell you how! I had the same problem but it's not problem but a lack of user's manual. In the automatic mode the searching through albums and artist on the on screen display is very slow. You are pushing and pushing and pushing the "menu" button. That was the problem! Connect your bridge and ipod and turn on the AVR. Switch to The Bridge as input. It will say that you are in manual mode. Push the menu button on the AVR's remote for a few seconds. And it will turn back to automatic mode!!! That's all! The real problem is neither of two manuals (The Bridge and AVR) tell any words about the function of holding down for seconds the menu button. Its function is to switch between manual and automatic mode!
I too was frustrated because of this. I played with the watch until I found the solution. Hope this helps!
For some reason I needed to be in the training mode to do this.
From the Time/Date mode, do the following: 1.) Press the start/stop button (upper metal button) to get out of Time/Date mode 2.) Press the Training side of the bezzle. You will see a workout display. 3.) Touch the GPS side of the bezzle until "to location" shows up 4.) Press the lap/reset button (lower metal button) to display a menu (may have to do this a couple of times, eventually when you release the button the menu does show up) 5.) Slide downward through the menu options until you find GPS 6.) Click the start/stop button (upper metal button) to toggle the gps on or off 7.) Press the lap/reset button (lower metal button) to exit the menu (goes to the "to a location" screen) 8.) Press and hold the Training side of the bezzle to return to your training screen
Push the menu button (the one one with the file folder) until "search" is displayed. Push the down arrow key 10 times until "advanced menu" is displayed. Push the right arrow button until "format" is displayed, select "Format ok" and push the play button. Problem solved.
