Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
A
Anonymous Posted on Jul 11, 2014
Drayer repair? The dryer will not start - Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer Vent Cleaning
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Nov 27, 2014
Dryer Vent Cleaning
Contributor
Level 1:
New Friend:
Answers
20
Questions
Helped
10535
Points
25
Test your Thermal Fuse
I am working on a Cabrio drayer, the plastic piece is broken that actuates the start on the control pad. I was trying to replace the plastic panel just behind the control panel, but it seems I have to...
ebay or craigslist find a broken dryer for sale near you. I just replaced one of my customer old kenmore parts NLA I found it on craigslit $35. Just a suggestion cheers!
How i can replace duck kit
Lowes or Home Depot should carry that.
2answers
Tumble dryer not giving heat
is the drum turning?if the drum is ok sounds like the thermo fuse on the heater box failed,most of the time it's from a clogged dryer vent hose or wall vent,let me know what you find-mike
Nov 13, 2008 • Dryers
1helpful
2answers
L G DRAYER , HEATER NOT WORKING
Had the same problem on a whirpool drayer. Get our multimeter and check which heat fuse is broken. Take that one out and throw it in the floor until you have conductivity again. Clean drayer vents and heater. This worked for me, good luck. http://www.youtube.com/watch?v=UuFQOuSlzlw
Replacement of fuse and thermostat
NEED FUSE AND THERMOSTATE AND DIAGRAM
FOR MY
LG DRAYER
MODEL NO.
DLG 2524W
ART
THANK YOU
Dryer not starting
Dryer needs a new motor. I changed the thermal fuse and the dryer worked for a minute then stopped without the ability to restart.
Jul 05, 2008 • Dryers
Plastic wing inside the drayer drum fell
Replace the fin if you have found that it is broken.
2answers
Tumble dryer
Can be a few things. Start by resetting your circuit breaker. The dryer motor can run with partial power but the heating element cannot. Make sure your not set to a no heat setting. After those checks you have to get into the mchine to check your heating element and thermostats.
2answers
Drayer working but no heat
No heat may mean that one side of the 240 volt circuit breaker is tripped or one fuse of the 240v circuit at the fuse/breaker box is tripped. Just replace/reset the fuse or breaker which ever you have.
Dryers will have controls working but not heat if it happens to be that particular side of the 240v circuit that tripped or fuse burned.
Jan 30, 2008 • Dryers
Draye heat work but not dry
check your exhaust vent hose inside and outside your hose you should have alot of air coming from the dryer to outside this is where Id start
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
