Question about Home
Toilet whistles when flushed - Home
    New Friend:
  • 64 Answers
Replace filler valve..8-10 dollar fix
Posted on Oct 14, 2014
  • 471 Answers
That's probably because it doesn't know the words. Just kidding.
Whistling sounds usually indicate some type of restriction in the water supply. It may be the stop valve is not open all the way. Dirt or scale in the fill valve or lime buildup can also cause a whistling noise. check for these issues. and clean or replace parts as necessary.
Hope this helps.
Bob
Posted on Aug 01, 2014
2 Suggested Answers
6ya staff
SOURCE:
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My Kohler toilet is about
The valve that fills the toilet is making that sound... it is filling up with dirt and the water is struggling to get through the smaller hole...
heatman101
Posted on Sep 03, 2010
Toilet stools whistle after flushing
This could be caused by the sound of water jetting into the water tank. Just open the tap to the water tank slightly more until the whistling stops. The flusher valve in the tank may be leaking, causing the water jet to open again and the whistling noise.
Apr 26, 2016 | Home
How do I stop a 2 second whistle when toilet is flushed?
change the auto fill valve inside the tank, if thts not it go to a longer feed line.
Sep 29, 2014 | Fluidmaster Plumbing
Handle is sticking in one toilet the other toilet makes a loud whisteling noise after flusing
The handle is probably worn out on the first toilet. The whistling on the other toilet is probably from a restriction in the fill valve, if you can live with whistling, it's not really a problem. If not, I recommend trying a different type of valve.
Aug 09, 2011 | Toto Home
When I flush my toilet,and it starts to fill it whistles
There is dirt in the fill valve....the water squirting by makes the noise...
heatman101
Sep 14, 2010 | Home
My Kohler toilet is about 5 years old and is making this awful whistling sound after being flushed. What part needs to be replaced so I can make it quiet again!?
heatman101
Sep 03, 2010 | Home
When filling the tank, water squirts out from the top of the pipe (valve?), and makes sort of whistling sound.
This is Not and i know its rediekules a mistake lol
Sum velves makes dos do hat, the most simpel solusion if u cant live with it is to get a new velve or to try and get a lower cap that gous over that part, bt jip as a plumber myself i also vind it weard they make it that way
Plz rate my advice thanx
Jun 20, 2010 | Caroma 270W-RF Reflection Round Front...
I have a Jacuzzi Perfecta toilet (bought Aug. 21, 2008) at Lowe's. I have the sales ticket. The toilet works fine. The tank fills very slowly (2 minutes) before it shuts off. It also makes a whistling...
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Jun 10, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
How do I stop my bathroom tap from whistling
try fitting new tap washers - if it is an old fashioned capstan operated tap. If you have a ceramic valve (1/4 turn taps), then a new valve may be needed.
Nov 28, 2009 | Caroma 270W-RF Reflection Round Front...
Home Logo
252 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
