Question about Lisle Serpentine Belt Tool
V belts on a 3.8 v6 - Lisle Serpentine Belt Tool
02 Kia sportage intake and exhaust timing reversed and the engine was turned over but not cranked. Will this damage the engine? en
edited from article by Larry Carley, ImportCar, September 2001
Import interference engines include the following:
* Virtually all Acura and Honda 4-cylinder and V6 passenger car engines;
* 1994 and newer Audi 2.8L V6;
* 1998 & up Audi 1.8L;
* All BMW 2.5L and 2.7L 6-cylinder;
* All Hyundai 4-cylinder and V6 engines;
* Infiniti 3.0L V6;
* Isuzu 1.5L, 2.0L, 2.3L & 2.6L engines;
* Kia 2.0L in the Sportage,
* Mazda 2.0L in the MX-6 and 626, and the 3.0L V6 in the 929 and MPV;
* Most Mitsubishi engines, except the 1.8L, SOHC 2.0L 4-cylinder & SOHC 3.0L V6;
* All Nissan 4-cylinder and V6 engines;
* All Porsche engines;
* 1989-'94 Suzuki 1.3L DOHC;
* Toyota 1.5L Tercel engine;
* 1990-'92 Volkswagen 1.6L diesel; and
* Volvo 2.3L and 2.4L engines.
Unfortunately, the owners of many of these vehicles are totally unaware that their timing belt needs to be periodically replaced for preventive maintenance. The belt is out-of-sight and out-of-mind and, unless they read their owner's manual (which few ever do) and see the replacement recommendation in black-and-white, they usually ignore the belt until it's too late.
Another List
Interference engines .....
Kia 2.0L "Sportage"
Mitsubishi engines, except the 1.8L, SOHC (My Galant!) 2.0L 4-cylinder & SOHC 3.0L V6;
All Porsche engines
Toyota 1.5L Tercel
1998 & newer Audi 1.8L
Infiniti 3.0L V6
Try here.
Vehicle:2000 - 2002 Kia Sportage
Brand:Dayco Timing Belt
Fits Engine - Chassis:
2.0L, 4 Cylinder, GAS, FI, VIN "3", 3FE, Interference Engine - Base, Water Pump Driven by Timing Belt
2.0L, 4 Cylinder, GAS, FI, VIN "3", 3FE, Interference Engine - EX, Water Pump Driven by Timing Belt
Part #:DY95281
Description:DAYCO TIMING BELT -- Timing Belt (Camshaft), Self-Lubricating Fabric Provides Exceptional Resistance To Abrasion, Resulting In Extended Pulley And Belt Life, The Molded COG Design Runs Quieter And Is More Economical Than Chain Drives, Our Premium, High Modulus Glass Fiber Non-Stretch Cord Delivers Precise Length Stability To Keep The Engine Running Smoothly Over The Life Of The Belt, The Belt?s Compounding And Tooth Configurations Are Designed For Specific Applications Ranging From Normal Service To High Performance And High Temperature Engines
Google this."Kia 2.0 DOHC interference engine?"
Jul 23, 2018 | Kia Cars & Trucks
2004 Taurus serpentine 3.0diagram
Robert, Serpentine belt diagram. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Install Replace Serpentine Belt Ford Taurus 3 0L V6 1AAuto com
2003 Ford Taurus V6 3 0L Serpentine Belt Diagrams serpentinebelthq com
2003 Ford Taurus Belt Diagram Am Having Problem Getting My
Aug 17, 2016 | 2004 Ford Taurus
Diagram to change serptine belt
Hi. Your Ford Taurus has 3 engines. They are V6 3.0L 182ci FLEX FI N 2, V6 3.0L 182ci GAS FI N S, V6 3.0L 182ci GAS FI N U. I am not quite sure what engine is yours. Anyway, i provided you a link where you can fint all these engine belt routing diagram. Pelase click here.
All the best!
Nov 10, 2010 | 2002 Ford Taurus
1997 Mazda MPV, 3-Ltr. V6, destroys Timing Belt
i need help install a timebelt in a mazda mpv? please help me out
Jul 14, 2009 | Mazda MPV Cars & Trucks
Where is number 3 cylinder
the left side of this picture is where the pulleys and fan belt(s) are , so you can see in relation to your motor where number 3 is , since you didn't say it was a V6 or 4 cyl , here is the V6 picture , if it was a 4cyl , from the fan belt area count back 3 , and that would be #3 cylinder also
J5
Jan 20, 2009 | 2000 Mercury Sable
LAND ROVER FREELANDER 2002 V6 MOTOR GAS MOTOR
there are 3 timing belt in the v6 model. next time make sure to make marking before removing the belts.
Nov 10, 2008 | 2002 Land Rover Freelander
Lisle Serpentine Belt Tool Logo
170 people viewed this question
Top Lisle Hammering Experts
Robert Wooley
Robert Wooley
john h
Lawrence Oravetz
Are you a Lisle Hammering Expert? Answer questions, earn points and help others
