1) You must LUBE inmediately the deck belt, this problem happen because the lack of maintenance. The machine has a device for protection for the electronic system, producing a shut down for to keep safe the electronic.
2) You must LUBE the rollers bearings too very well
3) Test the voltage input for motor, if there are the motor NEED REPAIR.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block .God bless you
