SOURCE: How do you unclog the drain hose on the Equator EZ3600?
you need to open the back and unscrew the clamp to take the drain hose off. if you are lucky, that is the problem. there is another hose that could be clogged between the filter and the pump which is more difficult to get to. or it may be that the pump needs to be disassembled and cleaned to get rid of any obstructions. or you may need to replace the pump entirely. service for these appliances is rather expensive...at least in ny. good luck.
SOURCE: cold water valve
Hi Yes I fixed it myself! lol I just tried every combo of wires that there was, and it is working gr8! Ty so much though, for having a site like this! I even called the Equator company and they could.n't tell me! Again it is fixed and thank so much! Rose
SOURCE: hi i ahve an equator ez3600 washer dryer unit
It may have been leaking from the drain pump and you may want to check if it the drain pump by opening the back panel and checking if it leaks just when the drain pump starts to function.
SOURCE: Equator EZ 2500C - Need a pump
You can contact Appliance Desk who carry parts for all Equator models.
You can get their contact information from their website www.appliancedesk.com and also place the order online.
