I have install new print cartridges and its asking me to close print access doors. I never has this error before.
SOURCE: Says printer cartridge access door open when closed
No it will not complain for an open door if there is no cartridge. There will be a separate warning for no cartridge or toner not installed error. You might want to play around with the cartridge door a little and see for a possible paper stuck somewhere inside.
SOURCE: Error - "Close cartidge access door"
By a door edge or on a hong extention
Look for a wire going to the the closing edge near thge latch or to a hinge- one of the hinged may have a curved arm going to a micro switch buried near by
SOURCE: Print Access Door?
Dis you put any packaging in the printer to protect it? Just make sure that there is nothing unusual under the lid.
SOURCE: Warning light: Close print cartridge access door
It coudl be the document feed cover. The door on the rear or any part that can be opened and closed.
See paper jam in trouble shooting section of your manual. It shows several thing being moved.
Link to manual below:
http://h10025.www1.hp.com/ewfrf/wc/product?product=421991&lc=en&cc=us&dlc=en&submit.y=6&submit.x=3〈=en&cc=us
SOURCE: close print cartridge access door. It is closed
try to use a pin to click on the switch for the door and see it may be not working
Testimonial: "Yes, this is the problem. The notch on the door needed to be very carefully bent to engage all the way. How long should the align cartridge take?"
