I have forgotten a security code for my phone is there by chance a code that I can use to disenable the one that I forgot,in order to access my cellphone ,because at the moment I can not access my phone as there is a keypad with numbers requesting a security code input,before the phone can be accessed or opened
SOURCE: nokia 3110c keypad lock forgotten
if you could get to settings menu and restore factory settings,your problem will be solved
SOURCE: how to reformat nokia 5130 c-2 with the security keyguard forgotten
Follow this procedure to generate your security code.This trick will work only when after your phone connect your PC via Usb cable. 1.Downoad [ANT] Simple Ant Simple.zip Ant Simple.zip2. If you have Nokia PC Suite running, be sure to close it by exiting from the task-bar icon.3.Extract [ANT] Simple ] and run Simple.exe located in the folder4.Connect the phone via USB(should be original Nokia Data cable) to the computer by selecting Pc suit/Ovi suit when prompt a message in your pone.5.After you've connected your phone, Click "Read Info"6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed onthe bottom panel as shown below7. Nowclick on the SERVICE tab and click on GET button under USER CODE8. Your security code should now be displayed on the right side of the application window. After all format it by selecting "Restore All" from your phone setting.Thanks For visiting Fixya
