SOURCE: samsung sch-r450, i need the 4-digit code to
try dialing #43574357* it should show you the sid meid min etc. make sure you write down SID. then go to settings from the main menu>press *>587846. in the MIN and MDN field put in 10 digit phone number and put in SID exactly the same as you wrote it down so if 0 is the first number be sure to put 0 and the rest of the numbers. the phone will reset and your phone WILL work
SOURCE: Does my Verizon cell phone (Samsung SCH-U410) have a sim card?
No sim card. verizon has an application called Backup Assistant.. It is free if you havea My Verizon account. 1.99 if you dont. It is fast take about 2imutes.Thats if you are staying with Verizon changing , upgrading phones
SOURCE: SAMSUNG SCH W750 FORGOT LOCK CODE
you can enter the hard reset code but that will delete everything on the
phone the code is *2767*3855#
The default code for the Samsung is 12345678
