Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
SOURCE: washing machine
Hey 4E error comes in case
1. No proper water supply
2. The Outlet pipe sould be at AT LEAST 60 CM to max 90 CM HEIGHT ie to the height of the washing machine, try putting the outlet pipe to the holder at the back of the machine.
[email protected]
SOURCE: Samsung Washing machine fault
I have foud a solution 4E error for my Samsung WD7101CKW. Water that comes inside washer is splitted in splitter with valves. One of these valves has a red label on it - this is a valve with restrictor of flow inside. This restrictor is used to limit flow speed mainly for testing purposes of pressure/water level sensor. Because of that restrictor (red cap with two holes of 0,5 mm diameter) blocked flow too much, after some time washer controller thinks that water has too low pressure.
Unplug washer, disassemble hoses from valves, disassemble valves from the washer (screwdriver needed), drill both holes in red restrictor to 1 mm (use 1 mm drill or just big needle). Assemble in reverse. Will work :)
Greetings - Thomas
SOURCE: E1 Code - tried fixing it according to manual still won't work
The error code E1 = Water
supply error -Not
enough water entering the W/M.
Try check water supply line is on and not have any kinked.
SOURCE: My washing machine is leaving
Describe the residue. If it's oily (black, dk green) then the seal is out of the tranny and oil is getting into the tub. Dry cleaning is best for oil based stains. Liquid dish detergent is good also. On white it is tough to remove. Your washer will need a new transmission or replacing.
If it is powdery I'd guess a soap buildup, especially if you've recently changed detergents. The new detergent is breaking up the old soap scum in the outer drum and it is redepositing onto your clothes. This should wash out/off.
Tip: If it's a soap residue, fill washer full without clothes with hot water. Add 1 gallon white vinegar and more hot water until the unit if as full as possible. Agitate 15 minutes and drain. Rinse with a full level and drain.
SOURCE: Our samsung j845 front load washing machine won't
SAME THING HAPPEND TO ME, SORRY BUT YOU NEED A NEW WATERPUMP, THEY GO ON THEM WASHERS ALL TIME. I REPLACED 2 AND HAD MY WASHER JUST OVER A YEAR. NOW ITS THE DOOR
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
