The inlet line to the water heater goes to the bottom of the water heater to prevent the cold incoming water from mixing with the heated water at the top. The tube going to the bottom can come loose.
Turn the water off and relieve the pressure by opening a faucet and remove the fitting where the water enters the heater. You can see if the pipe is still connected.
The cold main water pressure is too low to maintain a constant flow. Make sure you have no other appliences on, or your not comprimised by the lowering of pressure
F-20 error code in Whirlpool Duet Sport washing machine is indication of inadequate water supply. Check both hot and cold water supply lines to make sure machine gets enough water intake. If you do not have a hot water supply to the machine you can only run it with the cold temperature setting. This machine does not have an internal water heater and relies on the hot water supply from the house water heater.
There is too much pressure on the cold feed, reduce the pressure on the cold by partly closing off the tap on the cold.
Or ensure the hot feed is fully open and not blocked, check if there are filters inline - remove the feed pipes at the washer end and look into the inlet valves - clear if blocked.
The inlet valve is common to hot and cold water with only a small pipe to fill the machine, the cold water is being forced back up the hot water pipe due to the pressure you can feel the pipe cool down after running hot then go to warm, if hot water is flowing the pipe will stay hot, if not then cold is going up the hot pipe.
The plumbers screwed up when they installed your showers. There are two connections on each shower. one for hot and one for cold. they connected the two hot water lines together with a T fitting and then ran a line to the main hot water line and tied it in. Then they connected the two cold water fittings with a T and ran that line to the main hot water line and tied it in there instead of into a cold water line like they were suppose to. This is the only possible logical solution to this problem. They tied your cold water connections to both showers into a hot water line instead of a cold water line.
most new washers sense water temp and will try to adj final tub water temp by alternately running cold or hot as needed ..most hot settings are not faucet temp but a predetermined temp so if your hot water is 140 degrees coming in the control will switch the cold on to bring final tub water temp down to preset ..which could be as low as 100 degrees the industry's way of energy conservation
check to make sure that your hot water isn't connected to the cold side this is the number one cause for your problem all washers rinse in cold so if you switch to and its hot cold then your hose is on the wrong valve just switch the fill hoses see if that don't fix it
