HI what code are you looking for? whether it is network unlock code to unlock your Nokia 5130 mobile from network lock or else Security code ..If you are looking for unlock code then visit sites like UNlocking4Free.com they are generating network unlock code for your mobile model at free of cost .Else if you forget the security code then try to reset your phone using default codes like 0000 or 1234 .If this codes didn;t help to reset your phone then visit the same site which i mentioned here they are also generating master reset code for your mobile model at free of cost you can use it and reset your phone then assign new security code
You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
If you didn't changed your security code from the company default number than try this no.12345 and see whether it's working or not? If not go to the nearest Mobile Service Centre there it can unlock your code that are provided in your phone. Thanks for using FixYaAll the Best!
Try this instruction whether it is suit for you or not?1. Menu
2. setting
3. restore all factory
4. Put your security code 12345 if you didn't changed from the company default number.
In case if you had changed it than put your security code else if you didn't remember or forget your number than you should go to the nearest Mobile Service Centre for reset.
