When you connect your TomTom (using the TomTom HOME application on your computer) ... and you sign in to your TomTom account, it will automatically do a scan/search to see if there's any update(s) for your TomTom device.
If you see the an update (available) for your Navigation software, select it and proceed to download and install it. MapShare updates are also identified and can be selected, downloaded and installed (free).
If you're asking whether you can update the map free ... the answer is NO ... not from the TomTom website. You'll have to buy a map update (subscription) and download the new version of the map and install it.
SOURCE: TomTom Home does not recognise device
Have you created a TomTom account? For each device you own it needs its own e mail address which it links to and you need to be logged in when you plug in your Tomtom.
SOURCE: tomtom go 300
The tomtom GO 300 does not need an installation disk. It has firmware ( thats a sort of pre-installed software ) that is put on it at the tomtom factory. If the firmware has become corrupted it can be reinstalled or "updated" by logging on here > http://www.tomtom.com/plus/service.php?ID=17 then click the DOWNLOAD TOMTOM HOME Link. Then connect your tomtom to your computer with a USB lead. Run the TomTom-Home software you downloaded and select "UPDATE MY PRODUCT" . After that , if you don't already have one you will need a valid SD card for your tomtom containing the maps for your country and some other activation codes which you get when you purchase maps from tomtom.
SOURCE: Can't load Map update on TomTom XL 330S
You'll have to remove enough stuff to make room for the new map. I had the same problem which is how I found this site. Turns out, the new map is larger than the one that came on the unit. The 1 GB of available space is pretty much all used when you get the GPS. Just copy all the voices and POIs that you aren't planning on using to your computer in case you change your mind later (you can just download them again for free too). As for the voices, only one works for text-to-speech anyway and that would be Samantha though a male voice is available for download.
You'll need to clear just under 4 MB to make room for the new map, and that's if you haven't added anything. Having the drive/memory on this unit just larger than the map makes it very difficult to get much use out of TomTom's great add-ons.
SOURCE: tomtom one will not turn on has red flashing cross on screen
Follow instructions here:
http://www.tomtom.com/support/index.php?Language=1&query=red+cross&FID=1898
