SOURCE: tried inputting wrong code to my renault kangoo
go to ur nearest dealer and ask them to unlock it for you
SOURCE: The radio won't switch on in my renault kangoo van
you may have already checked, but if you pull the unit out of the dash, there should be another "in-line" fuse on the red wire, check that one too if you havent already.
SOURCE: Security code for Becker car radio
lost radio code of MB Becker truckline CD65 BE 7045 serial no 68015713
SOURCE: How do you input the radio code on a Renault
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
Testimonial: "Your advice was perfect and allowed me to get the radio working again. Seems so easy when you know what you're talking about!"
