SOURCE: I have a RCA Universal
try this
10180, 10171
Hope this helps
-Curtis
Rate my solution please!
SOURCE: need codes for rca tv using ge universal remote
Here Are Some codes 000, 003, 004, 005. 006, 007, 019, 096, 098, 099, 100, 101, 102, 103, 129, 179, 181, 188, 190, 203, 212, 233. For t.v.'s............Hope this is help full.. : )
SOURCE: I have an RCA L40FHD41
try these codes " 11447 11347 11781 10029 12187
10747 11147 11247 11547 10174
10679 10774 11922 11948 11958
10038 10093 11661 11917 11953
12002 10051 10090 10278 11047
11919 "
if those dont work then try this: "
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
Set the "Mode Switch" to the desired mode such as TV for a Television.
Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
Enter the code "991" followed by the "device number"
for Televisions
for "AUX 1" devices - VCRs or DVDs
for "AUX 2" devices - Audio
You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
You can try out each code by pressing one or more function keys such as power, volume or digit keys.
When you've found the setup code that works for your device, press the "Select" key. "
SOURCE: i need the code for a ge universal remote my tv is
Go on-line and look for the remote manual...... it should list the codes for all TVs it can address.
In order for the 3 component universal remote to control
your TV, you must program it with the TV code that matches
your TV. These instructions explain the preferred method of
programming the remote-the Direct Entry method.
1* Manually turn on the TV.
2* Locate the enclosed TV Code List.
Find your brand of TV.
3* Press and release the TV key. The
indicator light blinks and then remains lit
4* Use the number keys to enter
the first code listed for your brand.
After you enter a valid three-digit
code, the indicator light turns off.
Note: If you enter an invalid code,
the LED will flash rapidly for 2
seconds. Start over at step 3.
5* Aim the remote at your TV and press
the ON•OFF key. If your TV turns
off, you have found the correct code
6* Enter the code in the box provided
on this page for future reference
7* If your TV doesn't turn off, repeat
steps 3-6 above, entering the next
code for your brand.
OK
