I want to see the incoming call log in Panasonic Kx - T7730
SOURCE: Transfering incoming phone calls Mod. Panasonic KX-T7730
do you mean call divert?
its possible.
we could do it.
SOURCE: KX-T7730, all the phones connect with operator ring at the same time when having an incoming phone
please i need your help,i use KX-T7730 in my office and of recent when incoming calls comes in all the phones in the office starts ringing and also i would like to know how i can lock and unlock the phone so as to prevent other users from accessing it.Thanks
SOURCE: panasonic kx-t7730
Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
PLEASE vote if this was helpful
SOURCE: how to set the clock at a panasonic kx-t7730
Basically, there are 2 ways of programming the date
and time - the short way and the long way.
If you are using the KX-T7730 phone on a Panasonic
KX-Txx 308/824 system:
SHORT WAY:
From the Switcboard / Main telephone
( ext 101, 10 or 9 ) with the handset on the
cradle/hook:
1. Press PROGRAM 0
2. Enter Date and Time
( The format is: yymmdd,
1 to 7 1=Monday 2=Tuesday etc, hh:mm,
0 or 1 0=AM 1=PM ) see example
3. Press AUTO DIAL / STORE to save your changes
4. Press PROGRAM to exit program mode
EXAMPLE:
If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook:
1. Press PROGRAM * # followed by the system
password ( default is 1234).
2. Now press 000 and then SP-PHONE.
Enter the year.
3. Scroll to the month with the right scroll key
(located at the right bottom corner of the phone).
To change the month use the AUTO ANS / MUTE
button.
4. Now scroll right again and change the date and
day.
To change the day, again use AUTO ANS / MUTE
5. Scroll right again and the time will appear.
Set the time.
To change am/pm scroll to it, and again,
use the AUTO ANS / MUTE button.
6. Press PROGRAM to exit program mode and you
are done.
SOURCE: How do I change the time on a KX-T7730 phone?
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook:
Enter the year.
button.
day.
Set the time.
are done.
