Question about Maytag Neptune FAV6800AW Top Load Washer
Motor control board needs replaced price?
  • 335 Answers
FAV6800AW/FAV9800AW correct?
What error do you take to the console? LR maybe?
Part Number is 25001079 on Ebay
Appliance Zone punch P/N in price checker.
Sears Parts Direct so you can double check P/N.
Good Luck Rich
Posted on Jun 29, 2009
Anonymous
SOURCE:
Washer displays LR Locked Rotor when washer is on rinse cycle. Motor NOT spinning. What and where and app how much is the part?
Hello, The "rotor" is the actual shaft of the motor and depending on your exact series number (which can be found on the label inside the door) the motor and motor control board must be replaced together if it is series 88 or below (series 1 to series 88) the appx. cost for the motor kit including motor and control board is $300 just for the parts
if it is series 89 or higher then just the motor can be replaced w/o the board and the price is about $190 for parts then in either case i would estimate the labor cost of a repair company to be $175-225
Jul 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MLE2000AYW won't spin, motor wont ever move during motor control test in service document, I never get any output on the motor output leads to drive the motor. Switching power supply just...
Three places I check for appliance parts, besides the local appliance repair store, are:
RepairClinic: http://www.repairclinic.com/Circuit-Board-Or-Timer-Parts?s=t-MLE2000AYW-%3d%3dc13
AppliancePartsPro: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47166
ApplianceZone: http://www.appliancezone.com/SearchProducts.aspx?id=MLE2000AYW&ctl00%24MainContent%24btnSearch=GO%21
It sounds like you have gone through the tests in the Service Book, and usually when the motor won't spin it is the control board, the motor, or the wiring harness. If you are getting no power from the leads on the control board to the motor, I would replace the control board. If you had or have any codes that come up on the machine, what are they? I have had to replace many motor control boards, and everytime it gets the machine going again. Only a few times did I actually have to replace the motor. It sounds like your motor is fine though. The most common cause of failure in these motor control boards is electrical surge. Many control boards now have built in surge protection to help prevent failures.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 22, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
Does my maytag neptune fav 6800 hav A reset button. All lights are on after A thunder storm last night. I dont have A manual thanks
There is no reset button you can unplug the 120VAC power cord for 30 seconds or so then repower up.
Surge protection on the 120VAC outlet servicing the washer is a good idea going forward.
If normal operation does not return with the power up/power down then I feel you may have failed Control Board.
FAV6800A/FAV9800A Service Manual and Sears Parts Direct for reference.
See Sears Parts Direct or any vendor for pricing this is the Control board you need if yours has failed p/n 25001217.
I just checked Sears Parts Direct and they have it for $135.67 but is states back ordered. That is the best price out there. I wonder if they made a mistake in pricing.
With a Thunder Storm line transient there could be other issues Motor Controller or TDS sensor but I feel it will come down to the Control Board.
If you decide to go forward and replace I will give you some additional info on removing the Console and the proper way to remove the ribbon cable from the Console to the Control Board……Rich
Jul 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The belt on treadmill will rull at full speed, can't shut it down without turning it off.
Sounds like your motor control board has shorted you need to go to iconfitness.com got customer support then to parts replacement input brand name and model# you will get a exploded view of parts and price.
If you proceed in purchasing the part then you will need to remove motor shroud replace circuit board. You may need to do a speed calibration and it will come with instructions how to do that.
Mar 07, 2010 | Epic View 550 Treadmill
Dryer does not stay running once you let off the start button
You likely need the electronic control board, which supplies the power to motor once you release the start button. the price of the board is around $100. Need the complete model# for the correct part number and price.
Oct 20, 2009 | Kenmore 62602 Electric Dryer
Motor control board needs replacing
You need to get the model number off the door jam or from the back control panel to order the correct board.
Looks like the right one to me you have listed already , once you get the part number for the actual motor board then you can search on line for the best price on one.
Phil
Apr 15, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Washer wont spin
You may be right, but before you rule completely on the motor, have you checked the Spin Control (sometimes referred to as a Motor Control Unit)? My experience with this unit usually has the Spoin Control board going bad more frequently. There should be a tech sheet located inside the washer behind the front panel under the door somewhere. The tech sheet should include all steps necessary in determing how to rule whether the motor windings are good, or the whether Spin Control board has failed. If you decide to replace the parts yourself, you can find them at repairclinic.com and searspartsdirect.com. Repairclinic has better pricing, but Sears has better diagrams used in parts identification and troubleshooting. The parts you may need are as follows:
Repairclinic:
Item 1206430 Spin Control
Item 823073 Motor-sole
Searspartsdirect
Item 4 (p/n #134149220) Speed Control (Under "PANELS/HOSES" heading)
Item 19 (p/n # 131770600) Motor-sole (Under DRUM/MOTOR" heading)
Of course...you can do your own comparitive pricing if you don't wish to shop online. Just use the Sears part numbers as a reference.
I hope this helps. Post back and let me know if you need further assistance.
May 02, 2008 | Kenmore 43142 Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
208 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
