SOURCE: What engine should fit my 28´bayliner boat
Yes there is. Saw one at a boat show and I believe it was also Swedish. You may want to look for used replacements on the web. I do not know where you live, but there are boats on the Great lakes with low hours because of the short boating season. There are also victims of hurricanes with good engines down South.
SOURCE: I need a wiring diagram for a 1990 heritage 1600
wiring diagram for a 1990 heritage 1600 starcraft boat type this in and do a web search. Is the wiring for the boat are for the motor? Jim Retired OMC Mech
SOURCE: hydraulic going low only, not lifting up in my bayliner boat
If this is an inboard/outboard you have 2 relays for the outdrive. One is for UP and the other is for Down. If this is an outboard you may only have 1 relay.
You need to work with what is there to diagnose the problem. The down relay is working. It has a wire that goes to the pump on the transom. The UP relay also has a wire that goes to the pump. Disconnect the working wire from the Down relay and put the wire from the UP relay (to the pump on the transom) in its place.
Switch up/down wires if this is an outboard.
This will make the Down relay work the pump in the opposite direction. If the pump itself does not work both ways the pump is bad. If the outdrive now goes UP the pump is good.
Most likely the UP relay is bad. But there is a Tickler wire on each relay to make the Relays work. Check for Voltage at the Tickler wire-when you press the Trim button for UP position. If you have power at the Tickler the Relay is bad if it does not respond.
Make sure you get the proper replacement part. Most Relays are Negative ground. But boats can use Isolated relays which do not ground through the case.
This second type of Relay may have the same number of terminals but internally it is different.
I also have a Bayliner with the OMC King Cobra in it and had to work on my relays too.
SOURCE: i need wiring diagram for boat 1993 Bayliner jazz
can't start my 1993 bayliner 1400 jazz. replaced key switch, kill switch today. I got the boat last week running.
