Connecting a 3Com 2952 Plus switch to a Cisco 3750 switch
If you also have a standard copper cable (or a second fibre cable) connecting the two switches (for resilience perhaps?), this issue is probably being caused by something called Spanning Tree. This is implemented on switches as a 'loop avoidance' system, and can look like you have described with one end 'ip' and the other end no lights.
On the Cisco switch, get to a telnet/ssh/console session, log in and enter show spanning-tree and press enter.
have a look to see if the fibre interface has a status (sts column) of BLK. If it has, then this is called 'blocking' and will remain like that until you remove the second link to the other switch.
Hope that this has helped!
