SOURCE: Zebra Z4m printer
you can change the backfeed option under the driver settings, I would also turn you print speed up too (on same tab) it sounds to be set on 2.5ips, crank it up to 7ips or higher
best of luck
SOURCE: Cancel Job
The only other way you can stop it is to stop the print job from the computer. Press the start button. Press the control panel. Select printers. pick the icon of the printer and double click it. Highlight the print job and press the delete button.
That will canel it.
SOURCE: ZEBRA Z4M PRINT QUE ERROR
I would say the printers buffer has overflowed, try looking around for a Print Buffer to hook up to the printer. The standard Flash is getting very hard to find.
SOURCE: Error in Print Jobs in the Queue
The use of a Print Buffer will help, the problem happens when there is a buffer overflow. Reboot the printer and let the print queue to resume will fix it every time, a print buffer will help with the overflow, try get one with a fair bit of RAM
SOURCE: Z4m printer will miss labels in jobs.
Check the label size is set correctly in the application. Try using a driver from Nice Label or Seagull Scientific websites to suit Z4M (Not Z4M Plus). Recalibrate the printer and try again. Remember to setup the driver correctly because the driver will override the printer settings.
