I HAVE A BRAVOS ECOCONSERVE TOP LOAD WASHER AND THE SCREENS ARE PLUGGED BUT I DO NOT KNOW IF I CAN TAKE THEM OUT TO CLEAN THEM OR HOW I CAN CLEAN THEM?
Good question! I wondered this too... But I just did this last week and I was successful... Lets see if you can be too.
First.. How old are your hoses? Are they getting stiff? Maybe time to invest in new ones... Especially the hot one... For heat makes these hoses age quicker.. And pick up a couple screen type hose washers for each end, if they are not already on your new hoses... Or if you are not changing hoses this time.
OK... Now you see how to turn off the water?
Turn it off and bleed the pressure off by attempting to fill the machine....
Now a pair of slip joint pliers helps to loosen the connector. . start at the supply valve end... See the screen... Right there in the end of the hose? Is it dirty, clogged? Or maybe even rusted and failed? Maybe you are glad you invested in the new hose? If so, just install the new hose. If not... Do you have access to compressed air? Can you take the hose to a friend and blow it out?. If not try removing the screen type hose washer... If you have to destroy it getting it out... You have new washers.. Install them... Likely there is one at each end.
Now... Before you hook it all back up... Can you blow air thru the hose easily? Then hook up the hoses to the water supply ends at the wall... Put the hoses in an empty bucket... Turn on the water valve... Do you get a real strong flow of water? If so.. You are ready to connect to the washing machine end also. Now does the machine fill up g fast again? What did you find? Let us know... We are here to help. MB
SOURCE: Maytag Bravos top load washer
Did you try readjusting the load, or maybe removing heavier items?
SOURCE: How do you select the load size on the Maytag
You do not select a load size, the washer detects the load sizes, then uses the amount of water etc.
SOURCE: My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
SOURCE: I have a Maytag Bravos MTW6600 top load washer. I
Hi When you hear a humming sound from the motor it means that
the motor control is bad and should be replaced. If you still want to test the motor control then you can take it apart and test the motor before replacement. Hope this
helps...please post back for further assistance. Daniel
SOURCE: How do I clean the
puncture the screens with a hook tool,they just puull out,they are limed up and are only stuck in the water inlet
