Mitsubishi WD-73827 73" HDTV DLP TV Logo
A
Anonymous Posted on Jul 14, 2014
73 inch tv speakers are off how do you turn them on
73 inch Mitsubishi manufacture date 2004
Jim Cates
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 15, 2014
Jim Cates
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
431
Points
Go to menu and click on sound on this click to see if speakers are turned on if not click on if that doesnt work try the try the return to factory settings..
5 Related Answers
Anonymous
  • 668 Answers
  • Posted on Jul 18, 2009
SOURCE: My 73' rear projection Mitsubishi turns on, an in
It Sounds like to me that there is something with in the Optical block causing the problem.
I would recommend a professional to look at it and confirm this.
Hope this helps,
Skyassoc
Anonymous
  • 5138 Answers
  • Posted on Aug 19, 2009
SOURCE: Hi there...I have mitsubishi WD-73927 manufacture
If your TV is DLP , Then your Light engine is Bad,when color changes and little spots appear it is light engine.
Anonymous
  • Posted on Feb 12, 2011
SOURCE: i have a grey box appearing in middle of my 73
turn off closed captions (worked for me)
Anonymous
  • 30 Answers
  • Posted on Oct 16, 2012
SOURCE: White Dots on My 73 inch Mitsubishi TV
DLP IC DEFECTIVE --Depending on model you may be able to just replace the ic --in others the complete light engine which is much more expensive
Anonymous
  • 7 Answers
  • Posted on Oct 22, 2012
SOURCE: mitsubishi 73 inch wd-73738 no picture
Take a flashlight and at a angled view see if you can see the picture, if you can the lights burned out in the back
I need a 73' tv screen for a mitsubishi model wd=73638
Contact the authorized service center for Mitssubishi. It can't be purchased from open electronic spare part market.
Electro help
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
sounds like the psu. power supply unit. check the caps are not bulged
I have picture but no sound on my mitsubishi 73 inch DLP tv how do i fix
check to see if with a rear audio/video input you have sound (DVD etc)
look in menu speakers are not set to off or external
try the reset: Menu 1,2,3, enter.
I nannot turn off cations on 73 inch tv
look for a button on the remote most probably labeled " CC " or go into the menu in the audio or setup section and you should find the closed caption settings.
1helpful
1helpful
Replacement lenticular screen for vs6041 60 inch mitsh
we recently cracked our lenticular screen on our 73 in mitsubishi i called the manufacturer and they said they no longer make them. so i looked thru websites to see if i could find some one with a 73 in tv or bigger that they were no longer using or didnt work and i found a guy on www.ksl.com that had an 80 inch tv and we went to go pick up screen cut it to my tv size and it worked!!.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
