SOURCE: SONY WEGA KV27FS120 WON'T TURN ON, LED BLINKS A FEW TIMES
I have a SONY WEGA 3 years old KV-32XL90E and have the same problem the Stand By/Timer light blinks 16 TIMES, pauses and then does it again.The sound is but no picture.
SOURCE: Best setup for Xbox 360 for Sony 32" Tube WEGA tv
Hi, Not sure whether you are kidding or not. You don't mention the tv model so I will try to help using a KV-32FS100 as an example. You really only have 2 choices assuming you have a current model xbox 360. The component cable that comes with the xbox has 6 connectors, a green, blue, red, yellow on one part and a white and red on the other part. On the back of the tv below and to the right of the s video connector are inputs labeled Y, Pb and Pr and are colored Y is green Pb is Blue and Pr is red if they aren't colored that is the correct order. Don't connect the yellow to anything. The red and white on the other part of the cable go directly to the right of these connections. It will say audio and L and R they should also be colored but if not white is L and red is R. There is also a small switch at the xbox end of the cablewhich you need to slide to HDTV. Once you are powered up don't forget to enter the setup menu on the xbox and select the settings for your tv. Again without knowing the model most wega tvs limit the component input to 480p which was the limit of a dvd. I hope this is helps.
SOURCE: Need free manual for Sony WEGA KV27FS120
http://tv.manualsonline.com/search.html?q=Sony+WEGA+KV27FS120+&submit.x=52&submit.y=17
Just go here in the middle of page there is a free user manual at&t thing pops up just click no thanks and that should get you what you need
SOURCE: how to hook up Xbox 360 Component HD AV Cable to Sony KP-53hs10
I would be surprised if this model has component inputs from its age and if so it is not a HD set.
